I would love it if someone could confirm this for me…I believe the engineered wood I joists, as I call them, are only to be used indoors, is that true?
Additionally, the certainly are not to be used in a vertical manner?
Thank you Forum!
Thank you Forum!
What does the specific manufacturer have to say? Their opinion is the only one that matters.
What Jeff said !
Thanks Jeff for the quick reply.
It was located under a front porch that was secured. I could only stick arm between the lattice and take pics.
OSB will not hold up in a damp environment, It will deteriorate at a fast rate.
And no they are not designed to be used as a post.
Yea that’s not going to hold up over time.
The homeowner “will never see or know it” special
At least not for a couple of years.
You guys are the best…Thank You
Gee, you don’t often see spaced sheathing used for floors.
My wife and I looked at a house to buy a couple years ago and there was a non permitted 2 bay carport. I found all of the studs were vertical I joists and all the roof framing was made up of I joists as well. I wasn’t impressed.
He must have pulled them out of a dumpster somewhere and thought he would build something out of them, A carport.
But not exposed to the weather like a carport. They also use them for rafters.
