Does anybody else use a Protimeter? I do and about to smash it on the ground next inspection I have. I get maybe three inspections under my belt before the battery dies.
That being said, does anybody have a good, reliable moisture meter they use regularly?
I have a survey master and I like it when it’s working. Unfortunately I get about 10 minutes out of one battery. So it makes it highly unreliable at inspections unless I’m always carrying a spare.
You know you can send it in to GE and they will fix it for about 60% of a new one. Typically they just send a reconditioned one that acts as a brand new one…
I have tried to contact GE but I can’t seem to find the right department to send it to. Do yo know where to send it for repair? It’s done this since day one.
Well, after getting passed around to six different people, I found that GE doesn’t own Protimeter anymore and it’s owned now by Amphenol. They want $325 to fix my Surverymaster even thought it’s never worked.
I took it to a local electronics repair shop and they said it’s pulling three times the power from the battery even when it’s off.
Kind of ridiculous and I don’t want to spend this much money just to get another faulty product.
Does anybody have a suggestion for a different meter? I talked to a few other people in my area that have Surverymasters and they all said they have the same problem with them.
I use an extech MO297. This moisture meter is awesome and very accurate. It can be used pinned or pinless, gives you relative humidity and temperature. Also has a IR thermometer if you need it. I can also Bluetooth it to my Flir camera if needed.
I would never trade it for another. cost is about $700.00. They make a model exactly the same but without the blue tooth for a little cheaper.
Edit:
I have not changed the battery since I bought it over a year ago.
I have two Surveymaster Protimeters. The only issue I have is wearing out the bottom portion of the shell from the floors. A battery lasts at least 6 months if not longer. No issues otherwise.
Agreed. I just bought the newest Surveymaster to replace a nearly 14 year old model, and the only issue was the peeling overlay (it didn’t look good in photos…)
(And the lost cap that lets you jamb the pins in your hand over and over.)
Got a Surveymaster. Works great. Battery lasts a year or so. Use it every day (except Sundays and the occasional Saturday that I’m actually off). Great tool. No complaints.
mauger
(Mike Auger, CMI - RI 43685, RMC-142, RMB-096)
19
