http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html
· p with Stainless Steel Housing
Double click on above image to view full picture
1-1/2 Horsepower Whole House Water Pressure Booster Pump with Stainless Steel Housing
Pacific Hydrostar - Item#69303
Read 22 Reviews](http://javascript<b></b>:showReviews()
Write A Review](http://www.harborfreight.com/reviews/write?reviewsku=69303)
This water booster pump increases water pressure for the entire home
Only:$159.99
Sale:$134.99
Qty:
This item may be available at your local Harbor Freight Tools Store
Add to Wishlist](https://shop.harborfreight.com/wishlist/index/add/product/8708/) View Shipping Rates
Product Overview</SPAN>
Customer Reviews
REVIEW SNAPSHOT®
by PowerReviews](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html)
3.1
(based on 22 reviews)
59%
of respondents would recommend this to a friend.
PROS
- Easy to use (6)
- Easy to install (5)
- Attractive (3)
CONS
BEST USES
**o **REVIEWER PROFILE:
o Avid do-it-yourselfer (6), Casual do-it-yourselfer (3), Professional (3)
**o **WAS THIS A GIFT?:
o No (4)
Write a Review](http://www.harborfreight.com/reviews/write?reviewsku=69303)
Most Liked Positive Review
I would buy this product again and again
This is the perfect booster pump for household use. ie, with two hoses running the pump maintains 50psi, no drop in pressure and maxium water flow in the system, price and quality,…Read complete review](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html)
VS
Most Liked Negative Review
piece of junk
it was very easy to install, and does give great pressure, those are the good things.
however, they keep blowing out, the housing that sits on top, where all the…Read complete review](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html)
[RIGHT] [RIGHT]Reviewed by 22 customers[/RIGHT]
[/RIGHT]
[RIGHT] [RIGHT]Sort by[/RIGHT]
[/RIGHT]
[RIGHT] [RIGHT]NewestOldestHighest ratingLowest ratingMost helpfulLeast helpful[/RIGHT]
[/RIGHT]
[RIGHT] [RIGHT]Displaying reviews 1-10[/RIGHT]
[/RIGHT]
[RIGHT] [RIGHT]Back to top[/RIGHT]
[/RIGHT]
[RIGHT] [RIGHT]Previous|Next »](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html#ReviewHeader)[/RIGHT]
[/RIGHT]
10/12/2014
5.0
Good quality pump. Quiet and quick.
By Transmitterguy
from Dubois, PA
About Me Avid Do-It-Yourselfer
PROS
CONS
BEST USES
Comments about Pacific Hydrostar1-1/2 Horsepower Whole House Water Pressure Booster Pump with Stainless Steel Housing****:**
Ok guys, Ive been using the HF water pumps for 15 years now, and the work well for me. My domestic water comes from a 500 gallon tank with 500 feet of pipe (300ft of 2"- 200ft of 1") approx 80 ft above my house up on the hill behind my house, fed by a spring of good water. Buy the time it enters my house I have 20 lbs of pressure already. I use the HF pumps to take it up to 60 lbs pressure. Until 3 weeks ago I was using HF Item# 69302 1 Horsepower Shallow Well Pump with Stainless Steel Housing. In 15 years I have gone through 2 of these pumps and not because they fail, because the impellers wear down and the pump runs longer and longer to make it to 60 lbs. So instead of fixing them I just replace them. Now, I spent a little more money and bought this pump and It works great! Pumps fast, hits 60 lbs pressure and shuts off. The instructions say that the controller will turn on at 20lbs. This didnt work for me since I already have 20lbs coming into my house, so I did not plumb the controller in. Instead I used my old pressure switch for my old pump (not the HF one, I bought a good high quality Square D brand, for pump control). The controller is still connected electrically but I set it on the side upside down (or It wouldn’t let the pump run, It thinks there is no pressure). I replaced the prime plugs, with pure brass plugs, because in the other pumps I had problems with them rotting away and leaking.But that may be because of my water may be a bit on the acidic side. I didn’t need the little tank under the other pump, I have an 80 gal pressure tank that allows long off times for the pump. So far so good, I’m going to get another for a spare.
BOTTOM LINEYes, I would recommend this to a friend
Was this review helpful? Yes](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html) / No
*- *You may also flag this review](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html)
Comment on this review](http://www.harborfreight.com/1-12-horsepower-whole-house-water-pressure-booster-pump-with-stainless-steel-housing-69303-8708.html)
7/26/2014
(4 of 5customers found this review helpful)
5.0
By Botsie
from Boerne, Texas
PROS
- Attractive Design
- Durable
- Easy To Install
- Easy To Use
CONS
BEST USES
This is the perfect booster pump for household use. ie, with two hoses running the pump maintains 50psi, no drop in pressure and maxium water flow in the system, price and quality, very good, 1/3 the price of others companies that I have compare this with My first pump would not cut off, I returned it and was given another pump, same problem and I realized at this point that the auto on/off will not work if you have a pressure tank in the system no problem, I installed a pressure switch and it works perfect ( cut on at 40psi off at 58psi. I bought a spare pump, because past experience, ie if it fails it will do it on a weekend or holiday. use gas tape ( yellow ptfe) on all connections.
10/12/2013
(5 of 7customers found this review helpful)
5.0
great pump for the price
By Bill
from kansas City
PROS
CONS
BEST USES
Great pump for the price, always starts and pumps never had a problem with the pump.
10/11/2013
(5 of 5customers found this review helpful)
5.0
Works.great for my whole house.
By Jeff the home improvement guy.
from Wasilla Alaska
About Me Casual Do-It-Yourselfer
PROS
- Attractive Design
- Easy To Install
- Easy To Use
- Outstanding Price
CONS
BEST USES
I installed this pump a few days ago. It works exactly as advertised. I am extremely satisfied with its performance so fa,r it has doubled maybe even tripled my presure though out the house. No problems like others claim to have had.
3/25/2013
(3 of 3customers found this review helpful)
5.0
Works for me
By Johnny McAwesome
from Workshop, GA
PROS
CONS
BEST USES
I’ve not had any of the issues that the other reviewers have had. It was not difficult to install. It has worked as expected and has given good service and good, consistant household water pressure (showers are great now). It is mounted in the basement and is quiet enough that I can not hear it operate from the living quarters upstairs.
