I have a copper water supply line coming through the crawlspace and someone had made a repair and had converted the 3/4" copper to 3/4" PVC sch. 40. A few feet later he glued on a PVC main water shut off valve. Is this acceptable?
ps. I wish I knew how to insert an image, maybe someone on the forum can tell me.
CPVC is typically used within a dwelling because of it’s higher heat resistance. PVC sch 40 can be used as a cold supply line from Muni meter to dwelling entrance shutoff without issue.
Most States either utilizing the International Residential Code, or using it as a model code.
Specifically, Table P2906.4 which lists PVC as an acceptable water service pipe, and Table P2906.5 which omits PVC as an acceptable water distribution pipe.
As alluded to earlier, I suspect it has to do with temperature.
PVC is suitable for cold (or rather, “non-hot”) water. It deteriorates when exposed to hot water.
Could be PVC, even when used for cold water applications, would be exposed to higher temperatures at hot water heaters, shower bodies, tempering valves etc.
Or it could be that they didn’t trust the average plumber to use PVC for cold and CPVC for hot
I realize the hot water issue & that’s not what I was saying.
That makes some sense, but I seriously doubt it’s going to get that hot to the point of warping/melting/distorting it. I would have a hard time “calling out” PVC 40 used for cold water distribution, despite what any list says.
