Hello all,
This is in Charlotte NC. I was doing my first 11-month inspection, I had several observations and feel that corrections are needed, but I would appreciate your comments:
The upper section shows flashing discontinuity, and the structure below is exposed. The flashing orientation is also against the water flows and would compromise its functions of water dissipation. The lower part shows a flashing-on-flashing, and I think the gaps are not good, especially the lower one, because water would enter between.
The downspout is missing (is it possible because the tight space below the gutter, so it is ok to leave it without downspout??)
The flashing extension is too close and may partially block the water flow (get rusty, etc.) (Is there a requirement between the on-roof downspout outlet to its obstruction? )
Thanks a lot in advance!
