Questionable wiring splice in sub panel
After inspecting a manufactured home that was built in 1977, I have some questions about a wiring splice that I found inside a sub panel.
A 100 amp breaker in sub panel #one feeds a 20-amp breaker in sub panel #2 for the furnace. A thicker gauge wire is spliced to a 12 gauge wire with a wire connector in sub panel #two. The 12 gauge wire feeds the 20-amp circuit for the furnace. Is this a defective installation?
Sub panel #two is also a Sylvania panel.
I think that the Square D breaker in the Sylvania panel #one is a defect since it’s a different brand.
I will attempt to display the photos below starting with the main panel at the exterior wall of the home, and then moving downstream to the second two panels that are inside.
T1IYNd_087
T1IYNd_089
T1IYNd_091
T1IYNd_092
T1IYNd_093
T1IYNd_094
T1IYNd_095
T1IYNd_096
T1IYNd_097
T1IYNd_098
T1IYNd_099
T1IYNd_100
T1IYNd_145
T1IYNd_146
T1IYNd_147
T1IYNd_148
T1IYNd_149
T1IYNd_150
T1IYNd_151
T1IYNd_152
T1IYNd_153
T1IYNd_154
T1IYNd_155
T1IYNd_156
T1IYNd_157
T1IYNd_158
T1IYNd_160
T1IYNd_161
T1IYNd_162
T1IYNd_163
T1IYNd_164
T1IYNd_165
T1IYNd_166
T1IYNd_167
T1IYNd_168
T1IYNd_169
T1IYNd_170
T1IYNd_171
T1IYNd_172
T1IYNd_173
T1IYNd_174
