QUESTIONS OF THE WEEK 8 December 2019 - Let's win some prizes!
PLEASE TAKE NOTE!
You may now choose what you want from the following list:
** $50.00 gift certificate from Inspector Outlet
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
** Case of books "Now That You’ve had A Home Inspection"
**** Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
The WINNER can now choose from any of the prizes listed above!
Request your choice by emailing [email protected] and submit your Mailing address for shipping.
Good luck! :crazy_face:
Question 1: The kitchen displayed is for a 2150 Sq. Ft. home built in 1998. Natural gas is available for ALL locations where it would normally and can be used. What is the significant issue displayed here?
Kitchen
Question 2: This is a picture of a window installed in a wood framed wall with a brick veneer exterior that does have a 1” air gap between the veneer and exterior wall sheathing. All first floor windows have this same issue but not the second floor windows. What is the issue displayed in this picture?
Window
Question 3: House was built in 1992. It is a slab foundation on expansive soils. There are a series of pictures below with numbers which all mean the same in each picture; 1 = Water meter, 2 = irrigation system backflow valve, 3 = new looking PVC pipe with screw off cap that could not be unscrewed for some reason, 4 = Location of the main house drain and main sewer drain clean-out risers. There are at least 3 issues to be noted in these series of pictures and 2 advisory (warning) notices that can be provided to the client. What are they?
House2
House3
House4
House5
House6
House7
House8
Question 4: Below is a series of pictures from a brand new construction electrical panel. The ones with the removed deadfront are the larger of 2 sub-panels. This is a two part question. What SIGNIFICANT safety issue can be found in this panel? The second question is once the panel has been inspected how would you deal with this issue on site?
Panel1
Panel2
Panel3
Panel4
Panel5
Panel6
Panel7
Panel8
Question 5: Obviously the pictures below are new construction but I do find this situation on homes of all ages. Building codes do not try to dictate common sense and as a result we see this issue from time to time. Here in the South we do place HVAC equipment in the attic area and systems are typically filtered there as well. What is the issue with this stair set?
AtticStair1
AtticStair2
Great questions, Manny!
Thanks for doing them… :smile:
How’s does this work? Do we send the answers directly to you right here?
Also, do all the pictures need to be answered to be in the race?
Hello Edwin,
You just need to answer the questions asked and put your answers here. The pictures are there for you to help identify the issues. You do only get one shot at answering (see instructions above).
Good luck and have fun!!
Okay thanks
Question 1. Return in the ceiling of the kitchen. This could allow natural gas of products of combustion from the stove/ oven to be distributed all thru the house
Question 2. This is hard to see without the total window view. What it appears to be is the brick casing comes up above the weep holes in the window frame which would allow moisture to drip into the cavity. This can cause mold growth and moisture damage.
Question 3. The water meter and backflow devices have been underwater at some point. Recommend asking owner or referring to sellers disclosure on previous issues with leaks or high water levels.
Backflow preventer for irrigation system: These items are required to be inspected on an annual basis. A backflow preventer is installed on an irrigation system to prevent possible leeching of chemicals used in lawn maintenance back into the city water supply when the pressure on the irrigation side of the system would be higher than the pressure on the city side. Recommend having backflow preventer tested for proper operation by a licensed testing company.
The newer looking PVC cap is further out in the sewer system than the original clean out suggesting some kind of a repair recently or at least more recent then the original installation. Recommend asking seller or referring to disclosure on plumbing issues in the past.
Sewer and water piping are in close proximity to each other. If the sewer pipe breaks or leaks it could allow for cross contamination of the potable water system. (Possibly where the water and debris came from in the water boxes???)
Question 4.
Well the bonding of the neutrals to the ground is non existent! Usually one side of the panel bus is the neutral and the other side is the ground. The ground in this main panel does not appear to be bonded to the neutral at all which can be an issue for electronics and safety. I would immediately let the buyer know the electrical system is unsafe since the pathway for current over-protection devices would not function properly. I would also recommend further evaluation by a licensed electrical contractor who is not the builders contractor. I do enjoy the use of the heavy gauge white wire connecting the two neutrals… (I like to send this type of picture to my electrician buddies so they can get a laugh!)
The entrance to the attic is supposed to be free and clear of obstructions and this on looks to have duct work over part of the opening.
The next and most serious issue is the lack of a wall at the attic stairs. In other word, If I fall off of the attic ladder I may fall completely down to the first floor. Recommend placement of attic ladder in a different location or construction of a wall at the hall of the stairs
I’m sure I missed something but this was certainly fun! I would appreciate feed back.
all of the above …I win !!!
My bad and both of you can have an additional attempt at answering the questions. My wording on Question 4 was improper and I have changed it above.
Those are hard, below are my observations from here…
1- return in kitchen - not allowed
2- damaged track
3- possible tree roots damage
4-contaminant inside the panel,recommend further evaluation by a qualified electrician.
5-install railing
Hello Marcel,
Because of the way this board apparently operates your post might have been delayed and you did not get a chance to read the post above where I corrected the description of question #4. As a result of my mistake I do extend the opportunity for you to re-submit your answers any or all if you wish.
Hey Y’all,
Before we get to far into this think simple on the issues. It’s hard to write the questions and provide pictures that would not give away the answers completely. There might be a little deception in there but not much and I am trying to keep out the really abstract issues which might be present but would require more wording and pictures for you to identify it. All of the issues I’m calling out in the pictures are clearly visible without the need for any additional descriptions or pictures.
I’ve been told the window question was a bit tricky so I’ll give you another hint or two. This is only occurring on the first floor windows as stated above. Look closely at the window track for the defect.
BTW Y’all are smoking hot on the answers and trails to the answers! :wink:
Question 4: I would add to this, since we now know these are both sub-panels, The ground wires at the bottom of the panel do not have protection as the enter/ exit the panel.
Return grill in kitchen ceiling could circulate cooking fumes (grease) into the HVAC system. Possible ceiling supply register is near the return. That section will not be efficient, it is only heating up the area between them, quickly recirculating.
Screen resolution limited - Drilled holes in the bottom sill? Fasteners? No good. Unable to observe weep holes. Window placement over the 1" gap? Hard to see.
Observation: Possible non original concrete sidewalk replacement in vicinity of utilities. Newish PVC cap approx. in line with sewer cleanouts. Large tree in the area of a sewer drain line - recommend sewer line camera inspection. Insufficient backflow prevention height ( if any) was a health concern. Review if directly connected to water supply line. Soil subsiding and moisture intrusion around 1/2 enclosures, enclosure top below grade and not level promoting moisture intrusion. Review if from sprinkler head, or leak around the meter/irrigation or elsewhere.
Raised beds adjacent to home exterior, insufficient grade to slab height. Trim vegetation away from home exterior. Termites not as bad here as elsewhere, so issue vs. advisory may be different.
Missing grounds at panel for 120 V branch circuits? Maybe they are there can not tell from picture. Check to see if the home has 2 wire or 3 wire outlets. If 3 then GFCIs are in order.
Service area for the HVAC is adjacent to attic ladder, kind of difficult to work off a ladder, or worry about falling.
Challenging questions Manny!
These guys are doing great Manny.
Yes they are but there’s still time to win the prize!
OK we’re going to call this one for John Paul de Oliveira as the closest and the winner.
The electrical panel question appeared to be a tricky one and good answers were provided but you would not really be able to see that from these low resolution pictures. The white jumper wire you see is between two neutral bars. The yoke was missing in this panel between these bars and there are no manufacturer provisions in installation requirements to allow this correction. But is that a significant safety hazard? Possibly but that would be for an Engineer or Electrician, or the manufacturer to determine. BTW arc welding in an electrical panel reminds one why they should always carry an extra pair of underwear to inspections! :stuck_out_tongue_winking_eye:
Kitchen
Answer 1: This home only has one HVAC system as most of this size home have. No return air point should be located in the kitchen ceiling of a home unless that system only serves the kitchen and is no less than 10’ from any cooking appliance. This return air point in the ceiling does not meet any of these requirements.
Window
Answer 2: The window frame bottom track has been improperly drilled to fit an alarm sensor (the circular, ivory colored area seen) as have all first floor window frames. Now if left unattended over time this can become an entry point for water penetrations into and possibly beyond the frame to the interior wall stud cavity.
House2
House3
House4
House5
House6
House7
House8
Answer 3: There are multiple issues to note in these pictures depending on how you view the situation. The three obvious issues are as follows.
  1. There is insufficient ground cover leaving exposed soils that can wash away and alter the grading and drainage pattern of the front yard. Soils are washing out as noted by the soils partly covering the water meter box cover at its lowest (front) edge. Washout is expected to continue until proper ground cover is provided to retain the soil.
  2. Just about all SOP’s will state that you report what is seen and even the Texas SOP does not require us to predict the future while inspecting. However a failure to advise clients of these issues that can be determined and/or expected from present signs and conditions is a disservice and can come back to bite you as well. The first issue is the improper grading near the water meter. Grading does provide a sufficient slope away from the front of the home (with exception of the blocked planter beds you can not see clearly) but at the water meter the soils are sloped back to the meter from both directions and soils are low at this point. Additionally the bottom of the sidewalk is exposed which can allow water to pool against the sidewalk and penetrate under it. This can contribute to heaving and settlement of the sidewalk.
  3. The irrigation system backflow valve is almost completely covered over with soil. There are actual multiple issues with this condition. First this displayed indication indicates long term soil movement causing the valve to be covered over. That means this valve has most likely not been tested in a very long time! This is an older valve and its condition is suspect. Keep in mind these valves can fail in their function and yet still allow water to flow forward as well as improperly backward. Next most if not all backflow valves of this type are not rated for installation below ground for this and other reasons.
I keep hearing that Inspectors should not report on anything that is not visibly present and/or not an immediate issue. I absolutely agree that an Inspector should not try to break out a “Crystal Ball” and predict the future. However just because a problem has not happened does not mean it won’t and not advising a client of significant potentials is a disservice to them and typically what comes back to bite you in the end. The following were two advisories I gave this client.
  1. It really was surprising that for a 27 year old, slab home on expansive soils that there were no definitive signs of foundation movement. But you can see that huge oak tree in the small front yard, the close proximity to the home, and in this case a suspect non functioning irrigation system (many signs to list) that this tree has a high potential to cause foundation movement when it draws a lot of moisture from the soil. Just because movement does not yet appear to have happened does not mean it can’t or won’t. This tree also poses a potential for root invasion under the foundation which can cause issues with sub-surface piping, etc. Root invasion is not limited to only these issues but others as well. I have actually seen roots penetrate a 10” poured concrete wall as viewed from inside of a crawlspace. It only takes the right conditions to have issues occur and they are easy to create.
  2. I specifically marked the unknown PVC cap (#3 on pictures) and the main clean-outs (#4 on pictures) for a reason. Did you notice the nearly new public sidewalk pour? Did you notice the unknown PVC cap and main drain clean-outs in line with each other and headed toward the street? Did you notice the huge oak tree in very close proximity to a possible main sewer line path? So what’s that all about?? There were no permits available to explain this work and this particular jurisdiction does require them for this major sewer line and sidewalk work. Even without availability of permits online this is something I would definitely put back on the homeowner to explain and that’s what I did! We can certainly wonder if that large oak tree to the left has played a roll in the need for this work and this client was concerned enough about this potential to ask. The buyer (client) needs to understand that some type of major work has been performed here and only the homeowner can tell us what was done and explain if all issues were properly handled.
Panel1
Panel2
Panel3
Panel4
Panel5
Panel6
Panel7
Panel8
Answer 4: If you look closely you can see that the branch circuit wires not cleanly and properly dressed in the panel. This condition has left branch circuit wiring in excessively close proximity to the deadfront panel screw holes as seen below. The potential is there to strike these wires when re-inserting the screws and causing an arc condition. I have actually twice in the same year, on new construction, experienced arcing when BACKING OUT THE PANEL SCREWS and that is bad enough. When this condition is encountered, regardless of whether you believe or not you can re-insert screws without arcing, you should never even attempt to! In this case it was possible to use 4 screws to hold the panel on and the remaining two were placed in a bag and taped to the panel. In other cases I was unable to replace enough screws to hold the panel in place and always carry cardboard and painters tape to seal over the panel to at least help prevent it from being totally exposed. Obviously it is put in the report AND the owner or Builder is immediately notified of the safety issue.
PanelAnswer1
PanelAnswer2
PanelAnswer3
Question 5: Obviously the pictures below are new construction but I do find this situation on homes of all ages. Building codes do not try to dictate common sense and as a result we see this area from time to time. Here in the South we do place HVAC equipment in the attic area and systems are typically filtered there as well. What is the issue with this stair set?
AtticStair1
AtticStair2
Answer 5: This stair set is used regularly for HVAC filter changes, maintenance, and in the case of this home the gas fired tankless water heater is located in the attic. This stair set IS NOT equipped with a sensible or safe guard on the right side to help prevent injury if a person were to fall from it, they would be headed down a flight of stairs instead of just to the floor or against a wall. In the case of this home that stair set had other, more safe locations it could have been placed. As Forrest Gump’s Mother always told him “Stupid is as stupid does!”.
Congratulations, John Paul! :smile:
CONGRATS JP & THANKS to Manny for the great questions! :cowboy_hat_face:
Congratulations John Paul, good job on this one.
Manny put a lot of work in this one.
