QUESTIONS OF THE WEEK December 1 to win Gift Certificates ~ Custom Videos ~ Now That You’ve Had A Home Inspection Books
PLEASE TAKE NOTE!
You may now choose what you want from the following list:
** $50.00 gift certificate from Inspector Outlet
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
** Case of books "Now That You’ve had A Home Inspection"
**** Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
The WINNER can now choose from any of the prizes listed above!
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Good luck!
  1. Is all spray foam insulation flammable?
    a) yes
    b) no
    c) depends
2) The International Residential Code requires cleanouts for drain pipes to be established at intervals throughout the drain system. What is the maximum allowable distance between cleanouts?
a) 50 feet horizontally
b) 75 feet horizontally
c) 100 feet horizontally
d) 125 feet horizontally
3) Which of the following would be most likely to have the highest R-value?
a) 6” fiberglass batt insulation
b) 2” extruded polystyrene panel
c) 12” cast-in-place concrete wall
d) Triple insulated glazing system with ½” air spaces)
e) I don’t care
4) Any issues? How many?
5) Everything OK?
sink
EXTRA CREDIT!
WHO sang this on WHAT song? , :cowboy_hat_face:
And when I disappear
I pray that I have left enough
Cool, Marc! Thanks. :smile:
Good questions Marc. Thanks
Thanks guys.
I think you know who the song is dedicated to.
  1. C - it depends. Most materials are flammable under the proper conditions
  2. C - less than or equal to 100 feet
  3. A - 6” of fiberglass batts
  4. A tempered glass sink basin, when exposed to rapid thermal cycling/stress can fail spectacularly. It appears the sink may not be draining well, and there is no visible overflow protection/relief. There appears to be glass (perhaps tempered) at the faucet with the same concerns as above. The GFCI may not be accessible.
  5. There is a mixture of PVC, ABS, and possibly CPVC under the sink, with the CPVC glued to a PVC 90. Additionally, the drain appears to have a negative slope from the wall to the trap. Finally, the use of a flexible rubber coupling should be a shielded no-hub coupling in above ground applications.
  1. Yes
  2. C
  3. A
  4. No Overflow; GFCI blocked
  5. Improper waste line coupling(today’s standard); dissimilar materials glued
  6. Ringo Starr “Fading In, Fading Out”
Good questions Marc, thanks for your time!
CONGRATS to William Forrest, CMI
Answer: Yes. According to the International Building Code, all Foam Plastic Materials (not just spray foam, but Styrofoam, sound proofing foams, extruded polystyrene, foam boards, etc.) must be considered flammable (no matter what any salesman tries to tell you.) Different manufacturers’ foams have different flammability. Currently, there are a number of foams that perform over and above the standards required by the International Building Code. However, the literature of each manufacturer’s foam should be reviewed before a project commences.
https://greenstampco.com/2011/news/top-10-questions-asked-about-spray-foam-insulation-and-their-answers/
https://www.tests.com/practice/Home-Inspector-Practice-Test
e) I don’t care
https://www.mometrix.com/academy/home-inspector-practice-test/
Both of you gave good answers to the pic questions.
Take a close look @ the dumb water director (spout?).
It’s off center & when I ran it the water spilled over the side onto the floor.
Great install blocking the GFCI-DUH.
Thanks to Nathan for including stuff on the tempered glass sink
The CPSC said there are mandatory standards for many glass items, but none
for sinks. The industry relies on a voluntary standard, which happens to be Canadian
And thanks to Bill for nailing the music.
The tune has a very special personal meaning to me. It’s so true.
Artist: Ringo Starr
Album: Choose Love
Released: 2005
Congratulations Bill for a job well done.
Congratulations, Bill…well deserved! :smile:
Great questions! Sad I didn’t have time to answer this week. I’m on a boat, barely any internet or cell service.
Looking forward to next week’s though!
Thanks guys
Congrats Bill!
Congratulations @wforrest!
