Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
When an asphalt shingle roof is installed over existing shingles, leakage commonly occurs at the
a) Eaves.
b) Penetrations
c) Ridge
d) Hips -
What is a required element of a contract?
a) Consideration
b) Real estate agent’s name
c) Seller’s name
d) Names of persons attending the inspection -
Potable water systems connected to lawn irrigation systems need to be protected from
a) Backsiphonage
b) Excess water usage
c) Mechanical damage
d) Low water flow -
If a system designed for use with natural gas is supplied with propane gas
a) No changes are needed for the equipment to function properly
b) The flame will be too high unless a smaller orifice is installed
c) The flame will be too low unless a larger orifice is installed
d) The gas regulator and valve must be replaced -
The house you are inspecting currently has a gas-fired furnace or boiler. Each of the following clues may indicate that the house also has an abandoned fuel oil storage tank EXCEPT
a) Small diameter copper tubes emerging from the inside of the foundation wall or the floor near the furnace or boiler
b) An approximately 1 ¼ inch diameter vent pipe outside coming from underground up against the foundation
c) The brick chimney serving the furnace or boiler has deteriorated mortar joints at the bottom
d) Your knowledge that the neighborhood had or still has some houses served by oil heat -
While conducting an inspection, your ladder falls over and breaks the homeowner’s priceless vase. What type of insurance is needed to cover the replacement?
a) General liability
b) Homeowner’s
c) Errors and omissions
d) bonding
