Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
A mechanical draft-venting system shall terminate at least ___________feet above any forced-air inlet located within 10’.
a. 2’
b. 5’
c. 3’
d. 6’ -
Most heating systems can be categorized in _____ways.
a. Two
b. Four
c. Six
d. Five -
1 foot of cubed water at 68 degrees weighs _____pounds.
a. 47
b. 62
c. 26
d. 55 -
One of the most trustworthy practices used to prevent wood sensitive materials from decaying is _______a constant uptake of moisture from the ground.
a. Contact with
b. Inadequate clearance from
c. Separation from
d. Direct connection with -
“V”s heave and pyramids fall.
a. T
b. F -
Which one does not cause concrete to dust?
a. Concrete set to slow
b. Inadequate ventilation
c. Concrete water content to low
d. Sprinkling of dry cement to absorb bleed water
