PLEASE TAKE NOTE! You may now choose from the following list:
** $50.00 gift certificate from Inspector Outlet
** Seventeen Custom Branded Videos value $50.00 ~ your choice! https://certifiedmasterinspector.org/video-contest
** Case of books "Now That You’ve had A Home Inspection"
**** Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins. The WINNER can now choose from any of the prizes listed above!
Request your choice by emailing [email protected] and submit your Mailing address for shipping.
Good luck!
A ______ valve can be totally open, totally closed, or any position in between.
2) The highest concentration of contamination is located at the _____ of the pool.
a) bottom
b) walls
c) surface
d) hand rails
e) top edges
f) bottom if baby peed!
3) On a structure, what’s the difference between dead and live loads?
4) _____ bonding is joining metallic parts to form an electrically conductive path that will result in electrical continuity between components to ensure that the electrical potential will be the same throughout
a) conductive
b) connective
c) alternative
d) equipotential
e) cast
5) Any recommendations for repairs here?
Dead loads are static or relatively constant ones. Live loads are variable, or moving loads. It’s the difference between the weight of the roof on the structure, versus a person walking around in it.
Equipotential
It’s a little hard to see the picture on my phone. Aside from some paint in there it looks like the drywall might cause the panel cover to sit “too high” when installed. The overspray would suggest work may have been done to the walls. I’d need to see a picture of the cover installed to see the alignment.
dead load: a constant load in a structure that is due to the weight of the members, the supported structure, and permanent attachments or accessories.
live load: the load to which a structure is subjected in addition to its own weight.
equipotential
paint and building material contamination on the conductors and inside the panel. Recommended licesened electrician for repairs of full removal of all foreign materials or panel replacement.
XTR) painter, drywall crew, homeowner special
1 full port ball valve
2 C
3 Dead loads are the load of the structure, live loads change such as human activity, or weather.
4 Equipotential
5 Most likely the panel needs replaced, most manufacturer’s require replacement of panels with contamination that can not be removed with a clean cloth.
This from Square D for instance:
**example quote from Square D company:
If any contaminant has entered the panel that cannot be removed by simply vacuuming or wiping with a clean lint-free cloth, then we would recommend replacing the interior of the panel. If paint, or some other contaminant, has left labeling that is affixed to the panel unreadable, then we would recommend replacing the complete panel. We comment in our current design of panel: “Allowing petroleum-based paint, solvents or spray to contact the non-metallic parts of this product may adversely affect user safety and impair reliability”. This is due to the chemical reaction of the petroleum base paint or solvent to the insulating bases used in the panel.
Regards,
Rick Snapp
Product Technical Support Group
Square D Company – Lexington Plant
Florida Building Code (which is derived from IRC) also addresses this issue:
Reference Florida Building Code E3404.7 Integrity of electrical equipment.
Internal parts of electrical equipment, including busbars, wiring terminals, insulators and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners or abrasives, and corrosive residues. There shall not be any damaged parts that might adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; deteriorated by corrosion, chemical action, or overheating. Foreign debris shall be removed from equipment. [110.12(B)]
Good questions Marc, thanks for your time!! Happy Hanukkah! Merry Christmas and Happy New Year! Wishing everyone a happy, healthy, prosperous New Year!!!
1- Gate valve
2- C surface
3- Dead loads are static forces that are relatively constant for an extended time.
Live loads are usually variable or moving loads.
4 D equipotential
5- No repairs only replacement.
The Voice Of Cheese… Frank Zappa
CONGRATULATIONS to Dave Fetty for winning this week’s questions!
Jacob, you were almost there, but on the painted over circuit breaker panel you recommended 2 options, one was Recommended licesened electrician for repairs of full removal of all foreign materials
The question was
There is no approved method to remove the paint other than vacuuming or wiping with a clean lint-free cloth
I don’t think the very heavy contamination is gonna be removed by simply vacuuming or wiping.
Replacement is recommended-period. No repairs.
MERRY CHRISTMAS TO ALL! Everyone who participated is a winner, courtesy of the Awards Committee.
A ball valve is a valve with a sphere (or ball) inside it. The ball is the part that controls the flow through it. A ball valve can be totally open, totally closed, or any position in between. Gate valves should be used only in the fully open and fully closed positions
What’s the Difference: Valves - Ball, Gate, and Globe Valve?
Ball, gate, and globe valves all open and close supply lines. But they work differently
a) bottom
b) walls
c) surface
d) hand rails
e) top edges
f) bottom if baby peed! surface How to Inspect Pools and Spas Course
Dead Loads: Dead loads consist of self-weight of the structure (weight of walls, floors, roofs etc)
Live Loads: Live loads consist of moving or variable loads like people, furniture, temporary storage
a) conductive
b) connective
c) alternative
d) equipotential
e) cast Equipotential
Paint contamination observed in interior of electric panel. Safety hazard and maintenance concern. Paint can interfere with proper connections between electric components or proper operation of circuit breakers, creating conditions where proper grounding and electrical connections are not present, possibly causing brown-outs, arcing, and fires. Paint can also cause the wire insulation to deteriorate. No approved method exists for cleaning contaminants from panel interiors or components such as bus or terminal bars, circuit breakers or fuses.
Who could have possibly done this one?? Now that I’ve done it all over and nobody else will accept me
The Voice Of Cheese
Album Uncle Meat 1969
Producer: Frank Zappa
Composer Lyricist: Frank Zappa
