A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice! https://certifiedmasterinspector.org/video-contest
All members are eligible… … … sorta… … …
Good luck!
Inspect this
2) Romex Conductor & Armored Cables cannot be used in residences higher than ___ stories
3) Inspect this
4) Main Advantages of Engineered Flooring (may be more than one answer)
a) It can be used in basements and over concrete slabs
b) It can be used over radiant-heat systems
c) It is water repellent
d) The core layer can expand and contract more freely without warping
e) All of the above
f) The base is not required to be WAFI-Waffle design
5) Another term for an electrochemical disintegration is ___
EXTRA CREDIT for the soon to be famous Inspectorsaurus T-Shirt
WHO sang this on WHAT song? Drink all you want, be the star of the star of the show
A device (likely a surge protector) is improperly connected to terminals designed for one conductor on the meter side of the disconnect. The panel side of the disconnect also appears to be doubled up.
3 stories
Suspected microbial growth inside a cabinet. Recommend it be properly sanitized and to consider indoor air quality testing.
