Questions of the Week May 10, 2024
HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping
Choose your prize from the following list!:
>$50.00 gift certificate from Inspector Outlet
>Case of books “Now That You’ve had A Home Inspection”
GOOD LUCK!!!
  1. What is the minimum and maximum pressure for a water supply system in a residential building?
a) 30 and 60 psi
b) 50 and 100 psi
c) 60 and 120 psi
d) 40 and 80 psi
  1. VOLTAGE cannot exist without CURRENT ~ true or false
    CURRENT cannot exist without VOLTAGE ~ true or false
  2. ___ ___ is an easy cultural control technique that helps promote healthy root development and reduce weed growth in turfgrass
  3. What is the difference between skylights, sky windows, and roof windows?
  4. Where is the maximum allowable working pressure of a storage tank and water heater required to be shown?
a) In the installation guide
b) Stamped in the metal
c) On a permanently attached plate
d) Either b or c
e) not required
BONUS:
WHO sang this on WHAT song?
I’m never ever comin’ home again
Great questions, Larry. :thinking:
all of the above…
  1. D
  2. False, True
  3. Lawn Aeration
  4. Skylight - a fixed window to let natural light into a room. they don’t open to allow for ventilation.
    Skywindow - dual purpose. Lets in natural light but also allows you to see the outside world. May also allow for some ventilation.
    Roof Window - literally a window on the roof. these are operational windows that can fully open and close so they can allow for ventilation and in some cases can also be an emergency exit. More expensive than skylights.
  5. D stamped directly on the metal tank, or on a label by the TPRV
Bonus:
Dan Hicks sang this lyric on “Lonely Madman”
Great QOTW, Larry :slight_smile:
Great questions Larry.
Keeps us old timers on our game. :wink:
Nice questions Larry !!
Great questions Larry! Thanks for taking time for QOTW. :+1: :us:
speak for Yourself, some of us are still whipper snappers… :rofl: :joy: :rofl:
Bumpity, bump, bump. :boom: :heavy_dollar_sign: :dollar: :moneybag: :boom:
1 d
2 True, False
3 aeration
4 Roof windows are operable.
5 d
Bonus Carol King Home Again
Bumpity bump :wink: :us: :us:
:wink: :wink: :wink: :sunglasses:
  1. d
  2. false, true
  3. Grass aerating
  4. skylight - let light in
    Sky window - can see through
    roof window - opens and see through
  5. d
dan hicks and his hot licks - lonely madman.
Anyone else want to try? :boom: :moneybag: :dollar: :heavy_dollar_sign: :boom:
  1. D
  2. False, True
  3. Deep watering
  4. Sky windows generally refer to windows fixed into the roof, roof windows must be installed in the same orientation and ‘in plane’ with the surrounding roof, a skylight is a fixed window installed on flat surfaces, and typically doesn’t open.
  5. D
This week’s winner is Bert Hull !!! :drum: :boom: :heavy_dollar_sign::drum: :boom: :heavy_dollar_sign: :drum: :boom: :heavy_dollar_sign::drum:
Congratulations @bhull1 !!!
You are listed here:
  1. d) 40 and 80 psi
  2. false, true
  3. Proper mowing
  4. Not a whole lot. Any glazed assembly that admits natural light through a roof can be called a skylight. Some manufacturers use the term “roof window” to describe a relatively large skylight placed low enough that you can see out to the landscape. So I guess if you can see only sky, it’s a skylight, but if you can see sky and land, you call it a roof window.
Also, roof windows are generally big enough to qualify as means of egress in case of a fire. That’s seldom if ever the case with a skylight. The term “sky window” is not as common as the others. At least one manufacturer uses it to describe huge glazed areas in a flat roof. Most skylights are meant for roofs with a slope of at least 15 degrees.
  1. d) Either b or c
    Such markings shall be in an accessible position outside of the tank, permanently affixed.
Extra credit:
Lonely Madman ~ Dan Hicks & His Hot Licks
WTG, @bhull1! :+1: :wink:
This is great THANKS to Larry!
Song reminds me when I left home at an early age & never looked back to return.
Congratulations, Bert.
