Welcome to another round of Questions of The Week!**
**Questions of the week:
Introduction and requirements:
A member of the Award Committee will post a question, at a random day/time.
A competing member may make one post per question thread to answer the question and the member’s winning entry must have all parts of the question answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Winnings will be limited to no more than 6 times in a given year, the objective is to allow as many Members a chance to win as possible.
Any disregard to the above and divulging the correct answers will forfeit the weekly winnings.
So please refrain from participating if you have already won in the maximum for the Year.
First correct answer (as judged by the Awards Committee or Poster of the Question) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Courtesy of Nick Gromicko.
Winners of the Question of The Week shall request their prize by emailing [email protected] and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
THANKS for being here and good luck!**
**The questions:
The highest level of contamination in a swimming pool is: **
a. On the sides because they have the largest surface area
b. On the bottom because everything sinks
c. On the surface
d. They are all equally contaminated
2. Manual 3 point valves function following the shape of the letter ______where the flow of water can come up the stem and be diverted to either or both branches.
a. A
b. K
c. Y
d. F
3. All 15 amp and 20 amp receptacles located within 30’ of a pool must be GFCI protected T/ F ****
There should be no switches within 3 feet horizontally from the inside walls of pools, spas or hot tubs unless separated by a wall T/F **
All questions from the Internachi pool inspection book.
The highest level of contamination in a swimming pool is: (surface)
c. On the surface
Manual 3 point valves function following the shape of the letter ______where the flow of water can come up the stem and be diverted to either or both branches (Y)
a. A
b. K
c. Y
d. F
All 15 amp and 20 amp receptacles located within 30’ of a pool must be GFCI protected T/ F (F) Must be located within 20’ of a pool.
There should be no switches within 3 feet horizontally from the inside walls of pools, spas or hot tubs unless separated by a wall T/F (F) No switches horizontally within 5’
