Receptacle orientation reminder
i was worried about that😉
In this area the outlets installed with the ‘ground up’ often denote a “half hot” duplex outlet with one receptacle controlled by a switch.
I believe the side outlet must have the ground slot (larger opening) on top.
Interesting, Peter, I never heard before.
Serves the same purpose as the ground pin on top.
You forgot one Marcel. In this case the ground pin is supposed to face True North. :wink:
Some inspectors call it out if it is installed only to “magnetic” north.
Me? I think that is being too picky. :wink:
There have been hundreds of NEC code change proposals to require a certain receptacle orientation and to date every one has been rejected. Install them whatever way you like.
Back in the day we used to install horizontal receptacles hot on top so when you had to work on them while energized it allowed you to see the hot terminals and not short them to the metal box.
True that, I remember a few burnt fuses. LOL
That would be too complicated for me. Magnetic north shifts by an average of 87.45” each day (the average between WMM2020 and WMM2025). To further complicate matters, that’s only an average. It can be anywhere from 65” to 110” on any given day. It gets worse. The shift isn’t always in a straight line.
Between the time I calculated the position and actually installed the receptacle, the position would have already changed.
