Receptacle outlet under food waste disposer
I meant Mike Auger sorry.
Mike called this a side note since that code section does not apply to the OP. It would apply to this type of installation.
https://lh5.googleusercontent.com/-1-ZAkfPdgvQ/TlECMYI_CaI/AAAAAAAAACI/DGuLhLwYEXU/w377-h546-no/Gem+box+nails.jpg
If I included a comment it would be an informational note, and not listed as a defect in my report. I’d go something like this…
Informational note: Although this receptacle box installation is technically acceptable and allowed, you may consider relocating the receptacle box to a position higher and on the side of the cabinet further reducing reducing the potential risk of water or fluid entry into the box in case of a leak or spill. Any modification to the electrical system should be performed by a qualified, licensed electrician. (have a photo with the comment)
Thanks Rob, I couldn’t find a pic like this one but I didn’t look hard either although I did find one of the other box
While I disagree that this should be in a report, that’s a great way to put it in.
Why stop there though? Why not recommend adding GFCI protection, or hardwiring the disposal?
That’s a good narritive.
Looks like a Boston loop vent to me, but it is definitely short.
