Your point?
There are more home electrical fires in this country than natural gas fires. Both the examples given in your article had damaged equipment; gas line damaged by a worker; disconnected regulator vent line.
Electrical fires generally occur along the same lines. i.e. damaged (age or improper install) equipment.
If you are going to use either energy proper maintenance and use is essential for your safety.
