I’m working on a report now that had a second furnace installed to heat an addition. The furnace was installed in the garage on the slab as it would be in a basement. It was heating a master bedroom suite that was an addition above the garage. There was an output register located in the garage.
Normally, when the heating system is located in the dwelling with a register into the garage that is a no-no. This is one of those DLR’s (Doesn’t Look Right). It was installed in 2006 at the time the addition was put on.
