Service Equipment
Originally Posted By: Matthew Metzger
At the duplex that we live at we have lateral service entrance. Out in the alley we have 2 meters (one for each side), and below the meters each “service equipment” (right?) boxes have a main disconnect. Now when I go inside and open my panel which I guess would be the “load side” (right?) equipment I also have a main disconnect rated at 100 amps. Can someone explain this to me. I thought that the service equipment was usually the first box after the meter and contains the “main disconnect”, does that mean that the next panel on the inside is a “load side” or a subpanel with applied subpanel rules?
Thanks Matt
Originally Posted By: bking
on a different setup:
I think that if the meter base also has a main circuit breaker inside of it the next panel is still a sub panel.
www.BAKingHomeInspections.com
Originally Posted By: rmoore
Mathew…
A "sub-panel", or "main distribution panel" with a remote service disconnect, can have a main breaker. The panel's main breaker, in itself, does not make it service equipment. Any panel "downstream" from the service equipment should still be wired (floating neutral bar) as a sub-panel.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Excellent, thanks guys, I appreciate your help!
Matt
If there is no single “main” only the ones for the separate sides of the duplexyou have “grouped disconnects” (up to 6) and they are both/all service equipment.
