Originally Posted By: dvalley This post was automatically imported from our archived forum.
Shawn,
I hope I'm understanding your question correctly, but all plumbing supply and waste lines are viewed throughout the inspection. They're under basins, kitchen sinks and the majority are located in the basements and crawls.
The materials that were used for the plumbing supply and waste lines should be identifiable by looking at it. These are then annotated on the report.
Originally Posted By: John Bowman This post was automatically imported from our archived forum.
What is a Service Line. Please elaborate so that we may be able to answer your question. Are you possibly speaking of “Water Supply Lines” and or “Grey water lines”?
Originally Posted By: jsavino This post was automatically imported from our archived forum.
Water mains are either copper or in much older homes galvanized steel pipe. Waste lines could be cast iron, or PVC. Lead was only used for the bend under the toilets.
Copper lines will have soldered joints, steel will be threaded joints.
Cast iron will be at least 3" round, and heavy with a hub on one side.
Go to Home Depot, and look at different pipe.
-- John Savino
HomeWorks Inspection Services, LLC
St. James, NY
631.379.4241
Originally Posted By: dsmith1 This post was automatically imported from our archived forum.
Lead service pipes where used up until the 1950’s and I come across them occasionally. I mention to my clients that there is some health concerns and the water should be run several minutes before using it. You can tell lead from steel because it has a larger diameter and it is softer when you scrape it. I have never heard of a cast iron supply.
Originally Posted By: kdemski This post was automatically imported from our archived forum.
Lead pipes are soft, bendable and will shine brightly when scraped. Galvanized pipes don’t bend and are threaded at connections and turns. I’ve never seen a cast iron supply line, but have seen many cast iron waste lines in older homes - large diameter, hub connections.
