Service Panel near sink?
Originally Posted By: bsmith
http://www.nachi.org/bbsystem/usrimages/p/panel-sink.JPG ]
Aside from the obvious clearance issue, is it ok for the panel to be right next to the laundry sink? I couldn't find any info on a panel adjacent to a water source but it just doesn't seem right.
Bill Smith
www.SmithHomeInspection.com
"The difference between stupidity and genius is that genius has its limits." A. Einstien
Originally Posted By: bbadger
Their are no NEC rules regarding panels and sinks.
The only NEC issue I see with a quick look is what you already know, the clearance around the panel.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Originally Posted By: ecox1
This could be a safety hazard so I’ll note it in the report.
Thanks gentlemen.
Bill Smith
“The difference between stupidity and genius is that genius has its limits.” A. Einstien
Originally Posted By: pabernathy
Bill,
One of the things to observe here is if the plumbing and so on runs above the actual panel itself creating a possible drip issue on the electrical equipment. I will assume you already checked that out but Bob is right in that most code issues do not directly effect this type of issue.
Paul W. Abernathy- NACHI Certified
Electrical Service Specialists
Licensed Master Electrician
Electrical Contractor
President of NACHI Central Virginia Chapter
NEC Instructor
Moderator @ Doityourself.com
Visit our website- www.electrical-ess.com
Both sets of pipes in the photo did not pass over the panel. I accept that there is no code issue here but it still doesn’t seem right. eusa_think.gif
Bill Smith
Originally Posted By: Jay Moge
i know that an outlet within 6’ of a water supply needs to be GFCI, but that panel should not get anything plugged into it, so i guess it’d be the same as if an outside sill c*#k was under a panel or meter. i’d note the caution, but have no clue as to a code.
Originally Posted By: ahalstead
Just as a quick aside … and something a bit funny… my sister recently purchased a house with the electrical service panel along the back wall of the tub! You could take a shower and flip a circuit breaker … if you dared!.
the service was corrected prior to her purchasing the home.
Allen J. Halstead
Tri-County Home Inspections
Ghent, NY
"...for your peace of mind..."
Jay Moge wrote:
i know that an outlet within 6' of a water supply needs to be GFCI, but that panel should not get anything plugged into it, so i guess it'd be the same as if an outside sill <b>c*#k</b> was under a panel or meter. i'd note the caution, but have no clue as to a code.
IMO you nailed it.
GFCI protection is required for receptacles not hardwired equipment.
Bob Badger
Moderator at ECN
