Had a home with 2 service panels each with 150 amp main breakers. There were 2 service wires coming in to each panel. How do I determine the service size?
Whatever is the smallest amp component is your amp size for that single service. If both are 150 amps, I write it as (2)150. Not really enough information to give you more advice.
