Just inspected this house - built in 1961 for naval base housing. In 1999, it was refurbished with a new roof, replumbed and re-wired.
The service panel has a 125 amp “Service Disconnect”, and directly below is a breaker with hand-written “MAIN” which is labeled as 100 amp. So, this would be 100-amp service, right? Buyers had a copy of a previous (2005) inspection which lists it as 125 amp service.
Also, circuit going to laundry has a weird configuration. Is on a 20-amp circuit from panel, but also has a fuse at the end…
