Originally Posted By: bsmith This post was automatically imported from our archived forum.
The main disconnect is located in the far right panel. The ground and neutral are connected. The center panel (aside from being overcrowded) also has the grounds and neutrals connected. Since it is after the main disconnect shouldn't the grounds and neutral float? The grounds and neutrals are also connected in the far left panel.
-- Bill Smith
www.SmithHomeInspection.com
"The difference between stupidity and genius is that genius has its limits." A. Einstien
Originally Posted By: Thomas Ogryski This post was automatically imported from our archived forum.
You are absolutely correct that the neutrals and equipment grounds should be separated in the two panelboards, with the neutral being insulated from ground.
As far as "overcrowded" is concerned, without even doing the calculation, i can tell that there is still plenty of room in the center panelboard. Messy, not neat or workmanlike, yes, overcrowded, no.
BTW, is that center panel a Square D "XO" style panel? If so, it is definitely obsolete & good luck buying replacement breakers.
Thomas-
Good call - it is a Square D "XO". If not overcrowded, it certainly must be considered at it's full capacity. Thanks for your reply. I appreciate it.[/u]
-- Bill Smith
