Shifted pier in crawlspace
What do y’all think of this?
Looks like it was built that way, from here anyway.
Cheers
Agree with Doug. Similar to technique of a Witches Bend with chimneys.
Thanks fellas.
Yep, agree with the guys above.
Any images outside?
Year of build please.
You sure that is not a pilaster? That would be a wide column.
A pilaster is a cosmetic rectangular element resembling an embedded pier.
Corbeling. A corbel is defined as a shelf or ledge formed by projecting successive courses of masonry out from the face of the wall.
Racking is defined as masonry in which successive courses are stepped back from the face of the wall.
Food for thought.
Looks more like a chimney base than a pier. What is it supporting?
It appears to have a termite shield on top. So it is a pier.
that bug is trying to get your arrow Roy…
Or another example of why you should never drink on the job.
