Just curious how many of you normally will test a shower pan for water tightness during the course of a typical inspection? I do not, however InterNachi is advertising this product which has me curious…
Essentially the pan fills with water but can still drain so that it will not overflow. Once filled, you are supposed to let the water sit in the pan for 20 minutes.
Yes it would be beneficial to be able to tell your client that the shower pan is not water tight and is leaking, however I would not want to be responsible for the potential water damage or leak THAT I CAUSED BY INSPECTING IT.
Let the debate begin…
