I don’t turn any valves that haven’t been in steady use. One day, a client started turning valves in the basement wall after I told him the laundry taps were disconnected. We went into the kitchen and “What the …” no water at the sink. I went back to the laundry room and turned the kitchen supply back on which had been turned off. When I got back the realtor was fussing with the shutoffs under the sink. Now, they got water and there’s a drip UNder the sink that wasn’t there before. :roll: Oh well, edit the plumbing page.
How timely.
My most recent install of a delta T/S faucet with mixing valve left my customer very angry at me.
“HEY ,whats up with the new faucet and no water??!!”
Well, sir the faucet is doing exactly what it is supposed to do considering the fact you have turned your hot water off at the waterheater because the hot side on every faucet in your rental property is leaking(more like streaming) and the stem on the shut off to the heater needs to be repacked.Would you like me to repair these items so that someone can use your new faucet?
Once he figured out I wasn’t BS’ing he was a bit red faced but all turned out well.
This is a good thing to point out Mr.King as new products come to use and we all need some re-education and updates.
This can be particularly interesting if you have a remodeled home that has galvanized piping and the hot water supply is lost volume.
You now lose the cold water volume as well.
A good thing to know.
Your client will be impressed with how you know about how things work.
