Fist time seeing this for me- Looks like the chimney was an add on at some point, and instead of removing the siding and flashing/j channel to the chimney, they installed the chimney over top of the siding, filling the gaps with mortar - No has a gap between the siding and the brick… Thoughts?
Is the chimney plumb? Are there cracks? Etc.
Unconventional chimney to house connection…
And describe what you see.
I nominate this for the WTF thread ![]()
I didn’t have the equipment to ensure the entire thing was plumb (4’ level only does so much lol) I wrote it up for the possible water intrusion, and unconventional build- Eval for attachment…
Not a bad idea! haha
Youse got’s eyeballs, dont’cha? Looks to me like the chimney (middle third) was falling (or FELL) and the repairs were made sometime after the siding was repaired. What’s interesting is the upper most of the chimney looks older and in need of repairs AGAIN!!
Another possibility is the chimney was tipping over from deteriorated mortar, and the middle third was repointed… and the siding was added to take up the gap to help hide the issue, and avoid the immediate need for a full rebuild!!
Agree… my eyeballs on the house/chimney intersection is usually all I need. That line is one of the most important (as in most costly if you miss it) places on a house to look closely at. Anything odd/unorthodox, etc. is going to get a pretty hard write-up. I’ve seen all kinds of craziness there… HUGE trim boards to cover a gap, gobs or caulking or mortar. Just too many expensive possibilities and I can promise the next masonry contractor that sees it is going to throw you under the bus.
Water will be trapped between the chimney and the siding and will never dry out. Next comes the deterioration and all the associated issues. An expensive fix. Write hard.
Btw, you don’t need a level to say the chimney was visually out of plumb.
yeah, the thing has pulled away from the wall. that’s about all you need to write about that. when they start pulling away, it usually doesn’t end well if left alone for too long.
So, how should this be flashed?
With a wrecking ball…
