Slab Concerns?
Originally Posted By: Joe Funderburk
This is an addition to a 30 year old house. The slab all the way around the addition was not in contact with the ground at the edges. I could stick my foot up under the concrete about 6 - 8 inches in some areas. Vinyl siding prevented me from determining depth of slab. (No gutters were provided either.)
Need information on how deep a slab should be and recommendations on how to address this.
Thanks.
[ Image: http://www.nachi.org/bbsystem/usrimages/0/091405_074.jpg ]
Thanks,
Joe Funderburk
York County, SC
Alpha & Omega Home Inspection, LLC
jfunderburk@aohomeinspection.com
www.aohomeinspection.com
Originally Posted By: jpope
The slab (it appears) is not the issue. There is no footing under the addition.
This would raise concern that permits were not obtained for the addition.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: bsmith
I did an inspection not too long ago with similar conditions. The homeowner had built an addition onto an existing patio slab. Looks about the same to me.
Bill Smith
www.SmithHomeInspection.com
“The difference between stupidity and genius is that genius has its limits.” A. Einstien
Originally Posted By: Jay Moge
you can pretty accuratly guesstimate the thickness by measuring from the floor to the window sill, and from the grade (or bottom of the slab) to the window sill. then do the math. but i agree, footing is a structral issue. icon_cool.gif
Originally Posted By: bkelly2
Quote:
The Arizona room appears to have been remodeled or part of an addition. If so, we recommend that you verify the permit and certificate of occupancy. This is important because our inspection does not tacitly approve, endorse, or guarantee the integrity of any work that was done without a permit, and latent defects could exist.
![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif)
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
Originally Posted By: Steven Brewster
Do you guys probe or dig out around a slab to determine if is footed correctly?
Originally Posted By: lkage
No, not unless there's reason. The slab in the above photo yelled "Look at me! Look at me, I have no footing! ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Thank ya’ll very much for your time and comments.
Thanks,
Joe Funderburk
York County, SC
Originally Posted By: pdickerson
http://www.nachi.org/bbsystem/usrimages/P/P1120017.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P1120004.JPG ]
Originally Posted By: mcyr
Paul; where is the slab? or is this a wood floor?
All I can see is 6x6 or 4x4 P.T. sill.
Marcel
Originally Posted By: jwilliams4
Yesterday I inspected a house with a detached garage built about
20 years ago. Poorly poured slab--no footer. At first I was trying to
determine how the upheaval may have occured--then I realized the
block-wall garage was sinking.
Gawllleey!!!
"not just an inspection, but an education"
Marcel,
The "sill" is actually a form board. It was left in place.
Paul;
Back in 1972, I built a duplex up in Madawaska, Maine which would kind of match the environmental conditions to where you are, and typically in the area you would pour the slab at the edge perimeter to about 12" to 18" thick and taper off to 4" or 6" slab.
Most usually, 2" of Styrofoam was added for frost protection and insulating values.
Having sold the building 15 years later, the conditions were the same and did not look like the photos you provided.
It is what we called in that time, a frost free floating structural slab.
Hey, it worked.
Marcel
