SOP for Ohio as Adopted by OHIB
You having fun yet Mr Evans?
It’s fun playing with idiots.
Seems to be a one trick pony and not the brightest one at that. He is persistent, but that doesn’t require brains or self-awareness.
Have you read NFPA 70?
That’s why it was clarified in 2014. 5 years ago.
You should get out more!
You are correct about threading me with lawsuits
Online now - https://www.com.ohio.gov/documents/1301.17.1.17-StandardsofPractice.pdf
T. A licensee shall inspect a property’s readily accessible components of the electrical system during a home inspection and report in the home inspection report the licensee’s findings related to all of the following:
T - 5. Interior parts or components of a service panels and subpanels;
“Interior parts or components…” That would require removing the dead front! Can’t report on them if I can’t see them.
Get ready for another load of BS.
That’s why I told them that leaving that in was confusing. They change the original “shall” to readily accessible per my request. That will be removed before the final approval.
The rules have to go through (CSI) Common Sense Initiative and (JCARR) Joint Committee on Agency Rule Review.
As you have found in “T” I share the law and facts. Nothing says that you can inspect the inside of a panel in Ohio. Read what you want into it but if are in Ohio you may want to get “I’m allowed to inspect the inside of panels” in writing from someone’s opinion that you can use in court.
What makes you an expert on Ohio law? Your NJ attitude?
You might want to get it in writing that you CAN"T remove the deadfront. No where does it say that!
I don’t have to be an expert in Ohio Law. I can read.
It doesn’t say you can’t do Professional Engineering but that is in another Ohio law. It doesn’t say that you can’t do an electrical inspection but that is in another Ohio law.
I know Ohio law - you don’t. Why would you want to tell Ohio inspectors what is allowed under Ohio law? Are you qualified to interpret Ohio law - specifically RC 3783? I am!
Only to you. The rest of us have the ability comprehend what we read.
Good - then in April I’ll make sure that you get a copy of the final version! He who laughs last!
Wow, you make it so obvious that this is all about your personal agenda
Yes, I have a dog in the fight. Never denied that. Does that change the facts? I help home inspectors here in central Ohio. It is more often that I throw the electrician under the bus.
Its all facts to me. None of this is personal.
No. You’re doing your best to harm each and every one of them.
You are really disingenuous. You are bashing the HI profession on your website. You should spend less time posting here and figure out how to spell check that website. Maybe Grammarly too! It is hard to pass yourself off as an expert with professional-level attention to detail when you have not mastered complete sentences. For the love of God at least don’t refer to yourself in the first AND third person in the same paragraph.
Welcome to the forum.
We haven’t heard from Mr. Parks in about 3-weeks so we may be rid of him.
From your mouth to God’s ears! :cowboy_hat_face:
