Spalling, with efflorescence
Originally Posted By: cmccann
Did a home today that had a half basement half crawl space. All along the dirt line, pretty much all the way around the foundation wall was some big time efflorescence with spalling. The spalling was coming off in sheets. It looked like someone cut 3/4 of the way through a onion a bunch of times. I could grab sections of the wall and it comes off in my hand. Mind you this is really only at the dirt line, with the spalling going up about 6". Any ideas on how to handle this? Thanks Chuck
NACHI MAB!
Originally Posted By: rcloyd
Chuck:
Is the wall wet or damp?
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
Russell, The wall is damp pretty much all the way around in the foundation. I got more info, It turns out this section used to be a basement, and was filled in with sand and dirt. The dummie forgot to treat the walls. He filled the basement in to get out of paying taxes.
NACHI MAB!
Unbelievable!! I have never heard of such a huge mistake by a homeowner. You had better recommend a structural evaluation of the
wall(s) by a professional engineer.
Regards,
Russell G. Cloyd
859-586-4591
Thanks, I already did. The owner claims it’s the previous owner who did it. Very strange, There is a lot to this I think that is missing. Like Jimmy Hoffa maybe!
NACHI MAB!
Originally Posted By: fbuttermore
Chuck, I realize that this was an old topic but discovered it while looking for different crawl/slab issues others have seen. What is spalling? I have never heard the term before.
Thanks, Frank
Frank Buttermore
HTI Inspection Services, LLC
"Inspected once, inspected right."
Originally Posted By: clawrenson
Spalling + Masonry References (scroll down on the web page)
http://www.nps.gov/goga/history/seaforts/chap9&10/brick.htm
Spalling is a loss of surface material due to moisture infiltration. It occurs when moisture inside the brick expands and contracts due to thermal action and when moisture evaporates at the surface of the brick.
Added from their website: Brick Spalling is Almost Impossible to Repair:
In some cases, individual bricks may be removed from the wall, cleaned, and reinstalled with the damaged face to the inside of the wall. Where spalling is severe, and reversing the bricks is not possible, remedial efforts may be taken to save the remaining fabric of the material. Remedial measures include application of a water-repellent coating or the application of paint that matches the original brick color. Application of protective coatings is not generally recommended but if used, the coating should be breathable and should not significantly alter the brick finish. If salvaged or replica bricks can be obtained, severely damaged brick may be replaced.
Ontario Home Inspections Inc.
Originally Posted By: rcooke
Great Post Thanks Claude .
I just went through a small town near here and the Beautiful OLD hotel is in the midst of having the old brick sand blasted.
It now looks like a dull blotter and I expect it will absorb water just like a blotter.
I had a hard time not stopping and saying some thing.
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: mthomas2
Brick spalling at grade:
http://www.newimagemasonry.net/Images/BrickBlkProb/Spalling.jpg
Understood, all.
Thanks for the replies. I am familiar with the issue just had never heard the correct terminology before.
Always learning.............................. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Frank Buttermore
Originally Posted By: Jay Moge
i maintain 15 24unit building that are all brick vanier, and my mason and i were talking about some of the orange bricks on the building that i thaught were spalling. he informed me that in the past 25 yrs he’s been doing this that he has learned to call them “orange poppers”. water is absorbed in these type brick that look like teracota, freezes and “pops”. then bug get in the small holes and birds actualy peck out the bugs (that part i’ve seen first hand) it’s not to be confused with spalling though it’s just as bad and just as hard to repair. icon_cool.gif
