Spectra Water furnace
Originally Posted By: Craig Shap
Has anyone every heard of a “Spectra Water Furnace”? I am not sure what this system has do with the heating and cooling of the home other than the home was heated through the floor system with a Geothermal heat pumping unit… The pump itself was located in the crawlspace… I have attahced a picture… But the home does not have an AC condencing unit as most all homes do (but not in this case). I have done some research on the Geothermal efficiency ratings and set up.
Has anyone come across this type of unit possibly located in the Northern colder states of the country.
I have no clue why the link is not working.
[ [b]Image:[/b] [url=http://www.nachi.org/bbsystem/usrimages/more/1030336.jpg.JPG]http://www.nachi.org/bbsystem/usrimages/more/1030336.jpg.JPG[/url] ]
CAS Atl GA.
The Hometeam Inspection Service
Originally Posted By: tallen
link does not work Craig
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
trying link as we speak. thanks
CAS Atl GA.
Originally Posted By: jpope
The double “jpg”
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Here you go
Paul
I am sorry Craig.
I have never seen anything like it ![icon_confused.gif](upload://qv5zppiN69qCk2Y6JzaFYhrff8S.gif) and I hope I never will
Thanks Paul - - for getting that image… (don’t even want to know how you did it).
CAS Atl GA.
No clue. Sorry,
Originally Posted By: jhagarty
Craig:
Ironic that you posted this.
http://www.waterfurnace.com/?src=overture/
I had been researching a 1996 WaterFurnace Spectra SX Series Geothermal unit today.
Unit is a Vertical loop system thru the Basement slab. This unit is installed within a Townhouse community which I found to be very unusual.
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: jpeck
The photo shows two circulating pumps.
Jerry Peck
South Florida
Flow Center
Joseph Hagarty
[email protected]
Phone: 610-399-9864
Fax : 610-399-9865
Geo Thermal Heat Pumps work just like an air source heat pump or a normal air conditioning unit.
The difference is that an air source heat pump or normal air conditioning unit have an inside coil and an outside coil with refrigerant circulating thru them.
A geo thermal heat pump (Spectra Water Furnace included) only has an inside unit because the "outside unit" is either water from one or more wells (open loop) or a water based solution circulating thru a closed loop of pipe buried in the ground (closed loop). Circulating pumps, such as BOTH of those in the picture, take the place of a compressor in the outside unit. Their operation is controlled by thermostats in the home.
Educational Links for those researching geothermal heat pumps.
Geothermal Heat Pump Consortium
International Ground Source Heat Pump Association
AN INFORMATION SURVIVAL KIT FOR THE PROSPECTIVE GEOTHERMAL HEAT PUMP OWNER
BY Kevin Rafferty, P.E.
Geo-Heat Center
Oregon Institute of Technology
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Erby - Just as I expected - your explannation realy puts things in perspective…I am sure there is alot more to learn. Thanks for adding the addtional links, I will do a little research on my own. eusa_clap.gif
CAS Atl GA.
