Yesterdays home had a split buss panel.It had 3 wires coming into it so I believe its a 200 panel. There were 12 circuits, 6 on each side. I am correct that it is 200 amp ? Sorry I don’t have a picture .
Split Buss
It could be. What size was the SE cable, and what was the max. rating of the panel?
Among other questions
Larry
Well, those were the first two basic questions that came to my mind prior to the first, second, third and fourth cup of coffee.
I couldn’t read the panel someone had put tape over most of the information and then pulled it off so there wasn’t any informion I could read. The wire looked a little slimmer then the wire size I normally see on a 200 amp service. Does this help ?
