A member just sent in a great essay response! Check it out:
View Question
Research & Writing Essay Instructions
- Choose one inspection article from the Library of Inspection Articles OR choose one illustration from the Illustration Gallery that directly relates to the areas covered within the Home Inspection Standards of Practice.
- Study the article or illustration.
- In the box below titled “Your Essay," write an essay that describes what you’ve learned from reading the article or studying the image.
Your essay must meet the following criteria:
- It must be written in English.
- It must be at least 80 words in length.
- It must be written at a minimum 4th-grade level.
- It must sufficiently comment upon the chosen article or illustration that is covered within the Home Inspection Standards of Practice.
- It must include a screenshot, an illustration, or an inspection image.
This research and writing assignment is very similar to what a home inspector does during a home inspection--researching and studying inspection images and illustrations, studying and referring to and applying a Standards of Practice, taking inspection images, making observations, describing components, determining the condition of those components, formulating opinions, making recommendations to correct (if needed), proposing the implication of not making corrections to a defect (if observed), writing notes, and communicating observations in written form.
You will submit your essay in the box that is titled “Your Essay.”
Please continue with the course after submitting your essay. If the essay does not meet the criteria, you'll be notified by email to rewrite the essay.
Garage Roof Trusses – Structural Concerns: A visual inspection of the garage revealed that roof trusses have been cut and altered. Roof trusses are engineered components and must not be modified without prior review and approval by a licensed structural engineer. Alterations, even when performed by a contractor, require engineered specifications to ensure structural integrity and safety. Unauthorized modifications to trusses present a potential safety hazard. Additionally, wood screws were noted securing the bottom chord of the trusses directly through drywall into the wall framing. This installation method provides little to no effective load-bearing or shear resistance. It is strongly recommended that the altered trusses be assessed by a licensed structural engineer and remediated as necessary to restore proper structural support.
