Thank you for sending the Fine Homebuilding article as a reference. After reading it carefully, I believe it actually supports a different conclusion than what the course material states.
The article notes that a gutter must be placed ‘low enough so sliding snow won’t tear them off yet high enough so the rain runoff won’t overshoot them.’ This tells me that gutter height placement is a balancing act, not a one-size-fits-all rule based on pitch alone.
In my 34+ years of field experience, the majority of which was spent in Illinois as a Union Carpenter Local 169 hand-nailing shingles, I have seen numerous instances where gutters installed too low on steep pitched roofs failed to catch water during heavy rain events. The water gained enough velocity and momentum off the roof to overshoot the gutter entirely. Overshoot is not the only concern either. Water that makes its way behind the gutter becomes a problem as well, unless the expectation is that extension flashing be installed above every gutter on a steep pitched roof. Extension flashing never looks good, and is always wavy, primarily due to being an afterthought.
The course states ‘the steeper the roof pitch, the lower the gutter should be placed,’ but in practice, this guidance as written can lead to improper installations that result in water overshoot, which I have seen firsthand on numerous occasions, and I believe this statement needs either further clarification or additional context to ensure inspectors are evaluating gutter installations accurately in the field. Could you clarify whether this is meant to refer specifically to the gutter lip’s position relative to the projected roof plane, rather than the overall height of the gutter on the fascia? If so, the course material would benefit from clearer wording to avoid confusion.
Additionally, since a significant portion of this guidance references snow and ice loads as a factor in gutter placement, should there be a disclaimer noting that these considerations may not apply in regions where snow and ice are not a concern, such as Florida, where I now live?
