Another new image added to the free Gallery: Gutter Inspection Checklist
The recommended slope is 1/4 inch in 10 feet. Your chart says “1/16 per foot minimum.” That is over 1/2 inch in 10 feet twice the recommended slope. May make the house look crooked.
Fine Homebuilding says you are both right.
“Ideally, gutters should slope down toward downspouts 1 in. per 16 ft., but this is not always possible. For starters, this may not look good: Next to a level fascia board, the steeper the slope of the gutter, the more it looks out of whack. As long as there is a slight pitch—say, 1⁄2 in. in 20 ft.—with no low spots en route to the downspout, a gutter will drain.”
“Ideal” is not the same as “minimum standard”.
you are both right.
Sloping and Placing Gutters - Fine Homebuilding
