Hello all,
I came across this yesterday. I have not seen this type of insulation before. At least in this form. I imagine this is fire friendly and some digging around seemed to back this. I am definitely going to comment on it. My question is, How often do you all come across this? When, and was this common? Seems like a bad idea. Very few comments I have read take the stance the drywall/plaster on the ceiling below is the fire separation and this is not a big deal. Either way, I’ll comment on it but would like your thoughts.
Morning , David.
Seem a product like this many years ago.
Expanded perlite comes to mind. Perlite provides a quick, inexpensive and permanent method for insulating masonry walls. EPS would be my second guess. although I have not seen clumps. It could have been a rigid sheet broken into small clumps.
Lets see what others have to say.
whats the age of the home? expanded polystyrene pellets were popular as insulation in the 50s and 60s because it was cheap, easy to install and had good R value. It fell out of favor because it is flammable and gives off noxious fumes when it burns,and is susceptible to water damage.
modern foam insulation is treated with a flame retardant but can still burn which is why some manufacturers call for a thermal barrier or ignition barrier to cover foam insulation
Not sure about the styrofoam-like material ( have never encountered it in an attic) but the fibrous, grey looking material (beneath the pile of dead wasps) may contain asbestos (possible ACM). I hope you were wearing at least an N95 respirator while in that attic.
Thanks for the info, Robert.
Built in 1948. Thanks for the info!
Thanks, Russel. I didn’t enter this attic due to safety concerns. I do wear my mask in every attic. Even the new ones. I observed from the ladder on this one. First attic I have had with gable access, so that was different.
