David, I have never seen this set up, but I am wondering if it is a primer for the sump pump and maintains a constant water level so that the pump does not dry-start
If this is on town water it could be a water powered sump pump .
I have one looks a little different works very well .
Not quite as fast as the electric one but does a great job .
Very low cost under $75:00 US money. Power failure and away it goes .
I do believe there should be back flow preventer in the line I have one.
Cost much less then 12 volt back up and no maintance .
Roy sr
It’s a water pressure powered back-up sump pump. Is uses water flow to suck out the water from the sump in case of a power outage or main sump failure.
Be on the look out for potential cross contamination concerns because of the water line being used to power the pump.
Looks like easy access for the, possibility of radon gas to enter
[http://www.epa.gov/radon/pubs/physic.html#Character](http://www.epa.gov/radon/pubs/physic.html#Character)
2nd para "radon gas can enter a home from the soil through cracks in concrete floors and walls, floor drains, sump pumps, construction joints, and tiny cracks or pores in hollow-block walls"
How radon enters your house-
a) cracks in concrete slabs
b) spaces between brick veneer walls that rest on uncapped hollow brick foundation
c) pores or cracks in concrete blocks
d) floor-wall joints
e) exposed soil, as in a sump
f) weeping drain tile, if drained to open sump
g) mortar joints
h) loose fitting pipe penetrations
i) open tops of block walls
j) building materials, such as some rocks
k) water (from some wells)
these INSIDE companies who love to install inside drain tile and baseboard systems w/sump pumps, 1) they drill HOLES in hollow-block walls 2) they often leave the bottom 6" or so of any crack in wall…OPEN 3) they often leave the ‘cold joint’ OPEN 4) some install sump pumps with no cover or cheap cover AND…they do NOT seal many, if any of the items listed above on the OUTSIDE.
This looks like a backup sump pump. Usually the backup is on a battery and is low power. Inbetween the two fercos is a check valve to prevent water from the backup from going back into the pit. These are common in areas with high water tables.
