surprise
Originally Posted By: kwilliams
I moved in about a year and a half ago,
assumed this was a bad solder joint patched
by harry. Just got around to fixin it
surprise, anybody have a clue as to what caused this. I am the second owner and as far as I know the house has always been occupied, no other problems with any of the plumbing, if it was caused by freezing wouldn't the other pipes have been affected ? This is a waste line, should not have had standing water in it anyway.
![](upload://muuqWRzbQjnJgbtdGiy9N7obbq7.jpeg)
Member - MAB
http://www.nachi.org/convention2006.htm
Originally Posted By: tvalosin
Wonder what “hobbies” prior owners had? Possible damage from chemicals from inside pipe, or, maybe there was a clog in the line and they used some potent chemical to clear clog. If the clog “dammed” the cleaner for a bit, maybe the cleaner attacked the pipe internally? Strange though, the longitudal fault. Some kid put a firecracker in there? I am curious as to what our plumbing specialists say. Was the pipe standard wall thickness? What does the inside of adjoining pipe look like? Sorry nothing conclusive, just conjecture and queries.
Tom Valosin, ASKUS Consulting Services LLC
Originally Posted By: Jay Moge
I’d venture to guess freezing. only because the horizontal pipe certainly looks newer than the rest of the plumbing. (no green corrosion like the rest.) and the weakest point in some copper piping is the seam with which it was assembled. drains do freeze. especially if the toilet was running at one point. that looks like a possibility too seeing the little water damage to the floor below the flange. like if the “trickling” leak eroded the wax ring.
Originally Posted By: rcooke
tvalosin wrote:
Wonder what "hobbies" prior owners had? Possible damage from chemicals from inside pipe, or, maybe there was a clog in the line and they used some potent chemical to clear clog. If the clog "dammed" the cleaner for a bit, maybe the cleaner attacked the pipe internally? Strange though, the longitudal fault. Some kid put a firecracker in there? I am curious as to what our plumbing specialists say. Was the pipe standard wall thickness? What does the inside of adjoining pipe look like? Sorry nothing conclusive, just conjecture and queries.
Good call
Cleaner gets my vote some cleaners are sulfuric acid and should be flushed immediately after plugged drain is cleared .
Roy Cooke Sr.
http://Royshomeinspection.com
what if the drain was frozen, thought to be clogged and HO tries a little “ram out” sulphuric acid based drain opener. that would super heat the ice, and pipe. maybe even hot enough (from frozen) to pop the poop pipe. icon_lol.gif
Originally Posted By: bkelly2
Is copper approved in NY as waste pipe?
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
I would think copper is approved every where .
That is all they had after lead and steel before plastic.
Most tail stocks from sinks are still copper.
Roy Cooke Sr.
Originally Posted By: apfaff
My plumber friend has told me he has been replacing almost a years worth of new construction copper pipes he put in eight years ago. Apparently, there have been several cases of seams rotting out from manufacture error. They get dozens of pinholes along the seam and rot from the inside out. This one could have eroded for a longer period before leaking. Then they patched it.
On a side note, I was remolding a home and opened up the plumbing wall and the cast-iron vent pipe had rotted along the seam. From floor to ceiling, sewer gases were trapped in the wall cavity. The horizontal waste pipe was rotted out along the top, not a seam, the culprit here is oxygen. Impurities at the seam are more susceptible to chemicals and catalyst like oxygen.
Aaron Pfaff
http://www.dedicatedhomeservices.com/
http://www.independentinspectors.org/wisconsin.html
Originally Posted By: dandersen
It looks like damage at the seam.
We started getting copper from overseas that was crap.
How old is the house?
The house was built in 1964, it is 3" copper
Member - MAB
another view
Member - MAB
