Surveymaster Protimeter
Originally Posted By: rzimmerman
Just took delivery on this new meter. The moisture meter use is new to me. I’m looking for some tips, advise, do’s and don’ts, false reedings etc.
PS. Tool Experts was out of stock. I called Pro-Lab and they matched the Tool Experts price but not the discount. As I needed it ASAP I took the offer. Eric at Pro-Labs is great to work with.
Thanks
Rob Z.
Originally Posted By: aslimack
Keep in mind that metal will give you false readings for raised moisture. Drywall corner bead is one you can familiarize yourself with by intentionally testing an area where you know corner bead to be present.
Carry back-up AA batteries as they do go through them if you use it regularly.
Adam, A Plus
Thanks Adam
