Suspicious situation
Originally Posted By: ismetaniuk
This membership was a big waste of my time!
Igor
Top To Bottom Inspections
Glen Spey, NY
Originally Posted By: dbush
Igor, is that rust or scorch/burn marks on the neutral & ground wires starting with the Service Entrance and going down?
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: jmyers
Igor,
I would say a loose lug. If I am not mistaken you can see in the pic you provided they lug is melted.
Did you mention that the neutral wire should not be running across the two service entrance cables?
Joe Myers
Igor
Glen Spey, NY
Originally Posted By: jfarsetta
Igor,
I agree with your assessment, except for the concern with regard to mixed neutrals and grounding conductors. As this isn't a sub-panel, I see one common buss bar all the time in older panels.
Joe Farsetta
PS?: You're right, the guy probably crossed his neutral and main and is still suffering from welder's flash as we speak! BAM!!!
Igor,
Good call. I always call for further evaluation by an electrician when ever I see melting or burning! ![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif)
Joe Myers
