Originally Posted By: lkage
http://www.nachi.org/bbsystem/usrimages/C/practice.jpg ]
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
Galileo Galilei
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Originally Posted By: dbush
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: dandersen
| dbush wrote: |
| Larry, how about WRONG. |
| Quote: |
| ...the electrician that wired it, should have his license removed and be required to read through some of the mindless crap that has been going on in this bb lately as punishment for endangering someone this way. |
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
| Jason Reed wrote: |
| Is this a service entry panel? |
| Quote: |
| I don't see a separate ground bus. |
| Quote: |
| I think the panel in the picture is a sub panel wired up with only 3 wires.
| Quote: |
| Looks like some noalox was in order on those main feeds. |
Galileo Galilei
| dandersen wrote: |
| L2 is overheated. melting insulation, discolored lug.
Ground wire touching the above wire and also discolored. I would worry about the main feeds which are about to go POW! |
Galileo Galilei
| jtedesco wrote: |
| Larry:
A few more items here that you discovered, how did you wite this up? |
Galileo Galilei
| Jason Reed wrote: |
| Isn't it necessary for a subpanel to have an unbonded neutral and separate ground? |
| Quote: |
| I only assume the neutral is bonded to the cabinet in this subpanel. |
Galileo Galilei
Originally Posted By: chorne
Originally Posted By: dedwards
Originally Posted By: rcooke
| lkage wrote: |
| ...call it like ya see it:
[ Image: http://www.nachi.org/bbsystem/usrimages/C/practice.jpg ] |
Roy Cooke Sr.
http://Royshomeinspection.com
Galileo Galilei
| Quote: |
Ground wire touching the above wire and also discolored. Wire behind the cover screw holes. Splices made inside panel with insufficient space. I would worry about the main feeds which are about to go POW! The rest of the mess seems operational, though a real mess. |
| Quote: |
| It is not my job or position to recommend that you purchase or not purchase any property. You appear to be familiar with and educated in residential construction principles. However, as a matter of record I urge that you consider all issues noted in these inspections. The listing real estate agent and current homeowner are obscuring information and flat-out lying about conditions of the house. The current home owners verbal disclosure during this inspection was inconsistent, inaccurate and totally false in some instances.
I am highly skeptical of any homeowner who provides inaccurate information and any representing real estate agent who allows and supports any misinformation provided by homeowners. Thanks, David A. Andersen |
Originally Posted By: Jay Moge
Originally Posted By: lewens
Just my usual 12.5 cents
