Technical bulletin on corrosion of fuel lines
Good stuff.
Closing the Inspection Blind Spot: Why Exterior Fuel Line Corrosion Demands a Callout
Chris Bocciardi
Owner
Mr Meter Painter
KEY TAKEAWAY: Federal safety standards place 100% of post-meter gas line maintenance and ownership on the property owner, not the utility company. Gas meter piping frequently falls into a blind spot between standard inspection categories, yet identifying surface rust and missing protective coatings protects home buyers from property hazards without exceeding general inspection standards.
Keywords: SOP, gas meter piping, gas,
plumbing, heating, exteriors.
Across the country, millions of residential
properties share an overlooked,
high-liability safety hazard sitting in plain
sight: corroded gas piping downstream of
the meter. Oxidation produces flaking rust
that degrades nominal pipe wall thickness
which can compromise piping systems.
While home buyers routinely assume utility
companies own all piping up to the building
wall, federal codes and national standards
place 100% of post-meter maintenance,
corrosion prevention, and repair costs
directly on the property owner.
