Test the message board here.
Originally Posted By: Webmaster
This is a ‘dummy’ post that you can use to test out the message board. Want to use BBCode? Try it here. Check out hte image function, or the list function, or whatever you want.
Code:
This is some Code
Quote:
This is a quote
Have fun!
Chris Morrell
Director of Information Technology
http://www.nachi.org/
![](upload://641bk1jmm4YwAu1a5ycr88cA5eZ.html)
Originally Posted By: ismetaniuk
This membership was a big waste of my time!
Igor
Top To Bottom Inspections
Glen Spey, NY
Originally Posted By: Chris Morrell
Go ahead and re-post them here…
Chris Morrell
Originally Posted By: dvalley
and more
David Valley
MAB Member
http://www.masscertified.com
Don’t Mind me. more sampling
David Valley
MAB Member
Quote:
I can't get the lettering to change colors. Anyways...here is a good pic...http://www.nachi.org/bbsystem/usrimages/wood damage Carpenter Ants.jpg
Does anyone have pics of termite damage?
David Valley
MAB Member
SORRY… This is what I meant to do… http://www.nachi.org/bbsystem/usrimages/0wood damage Carpenter Ants.jpg
I’m learning and I’m taking advantage of this post…
David Valley
MAB Member
Let’s try this one more time…Don’t mind me…http://www.nachi.org/bbsystem/usrimages/1wood damage Carpenter Ants.jpg
David Valley
MAB Member
David Valley
MAB Member
I QUIT
David Valley
MAB Member
Originally Posted By: jmyers
David,
Take out the [IMG] tags at both ends of the post. Etiquette is dictating that you do not post the image because those with slower connections take forever to load the post. If you take out the [IMG] tags it will leave the link to the pic without actually loading the pic when they view the post.
For example:
http://www.nachi.org/bbsystem/usrimages/2wood%20damage%20Carpenter%20Ants.jpg
Don't worry you will get it right, it just takes a little understanding of how HTML works.
BTW....it did not work because there were spaces between the words "wood" and "damage". There were also spaces between the words "carpenter" and "ants". When you place the image on the server you need to take out the spaces other wise you are breaking the link that HTML uses to post the image.
Joe Myers
Thank you icon_wink.gif Joe.
Lets try it again
http://www.nachi.org/bbsystem/usrimages/3wooddamageCarpenter Ants.jpg
David Valley
MAB Member
ONE MORE TIME
http://www.nachi.org/bbsystem/usrimages/4wooddamageCarpenterAnts.jpg
Why is this going to home page?
HEEELLLP
David Valley
MAB Member
David,
Did you take a look at the link for the picture I posted above. I must not have explained it very well. You still have a space in the link. Since you posted the link with spaces to the server you need to fill in those spaces with "%".
When you are uploading the picture to the server be sure you take out all the spaces between the words. Go back and upload the link again, this time without all the spaces, it will work fine. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
When it asks you to add the link to the post click yes. After the link is in the post you can backspace to erase the [IMG] tags at both ends of the link so it does not load when someone views the link.
Keep trying, you will get it.
Joe Myers
Lets try again…http://www.nachi.org/bbsystem/usrimages/wooddamageCarpenterAnts.jpg icon_razz.gif
Am I (Image Upload) Illiterate or What?
David Valley
MAB Member
David,
No you are not image illiterate. You just needed to place a space before and after the link! ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
You have, lets try again.....http://www.nachi....etc
You need: http://www.nachi....jpg
Make sure there is a space before and after the link.
Joe Myers
O.K. Joe… One Last try.
If this doesn’t work…I need to read more on uploading images. http://www.nachi.org/bbsystem/usrimages/1wooddamageCarpenterAnts.jpg
David Valley
MAB Member
David,
It worked just fine. See all ya needed was to learn where to place the spaces! ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joe Myers
Originally Posted By: Steve Yared
test photo
http://www.nachi.org/bbsystem/usrimages/MasterBath2i.jpg
