TPR Valve Placement
Originally Posted By: jclason
Saw a Sutherlands Water heater today. The outflow pipe (hot water side) of the heater came out of the top of the unit to a sideways T-joint. The TPR valve was placed on top, and the discharge pipe was present. The hot water exited through the side of the joint.
The Sutherlands water heater had a plug in the location that the manufacturer specified for the TPR valve placement.
Does the location of this valve make a difference its operation (would it still work there)?
Thanks!
Originally Posted By: jpope
Most definitely.
jclason wrote:
. . . (would it still work there)?
It must be installed on the tank. It sounds as if you are saying that it's on the HW supply line. If this is so, it's a pressure relief valve and not a combination temperature pressure relief valve.
If the TPR is in the top of the tank, it's okay.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Thanks!
Great location lots of info
http://www.rheem.com/Documents/ResourceLibrary/TSB_Common/1220.pdf
Roy Cooke Sr.
http://Royshomeinspection.com
Great publication Roy, thanks.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Thanks! Jeff, you described it exactly. And thats a good link for information.
I noted that the TPR was not installed per the manufacturers specifications, is unsafe, and corrections should be made.
Thanks!
Originally Posted By: jwilliams4
IRC 2803.4 UBC 608.3 TPR to be located in top 6" of tank.
“not just an inspection, but an education”
