Originally Posted By: cobarr
http://www.nachi.org/bbsystem/usrimages/D/DSC01444.JPG ]
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: bkelly2
“I used to be disgusted, Now I try to Be amused”-Elvis Costello
Jay Moge wrote: |
looks like they did it the hard way. wouldn't it have been easier to just extend the hight of the t.p.r. valve with an extiension of about 2 or 3 inches (or what ever it needs) under it rather than all that soldering??  |
Jeff Pope
(661) 212-0738
Jay Moge wrote: |
oh. i see t.p.r. valves on comercial boiler that are mounted right on the manifold and on an extension. is this also wrong?  |
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
bkelly2 wrote: | ||
As long as the temperature sensing part of the TPR reaches into the boiler probably not. For residential water heaters if you just add an extension the temp probe will not be long enough. |
Originally Posted By: mthomas2
