Unique TPR Install
Originally Posted By: jpope
What else can I say?
![](upload://bL3siJsAyVbX8F2s9v191JNVAaM.jpeg)
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: dedwards
LOL! Oh yeah, that’s gonna work great.
Originally Posted By: ssmith3
Also looks like the vent is disconnected.
Scott Smith
Marinspection
Vice President NorCal NACHI Chapter
I graduated from collage. Now my life is all mixed up.
Originally Posted By: five.five
I think I saw plumbing like that on the Three Stooges a long time ago.
Originally Posted By: Aaron
Technically, if the pipe going to the left is just a pipe going nowhere, it would work still. The PSI in the water heater is the same as where the TPR is.
Even though all water heaters now have a port on them, thats how they did it when the old water heaters didn't have a TPR port on it....
Originally Posted By: ekartal
Notice the serious corrosion at the shut-off.
Erol Kartal
Erol Kartal
Yeah.... it all needs to be redone. I mean, technically, it doesn't, but if it was my house, I would.
The pipe you are referring to is the discharge pipe.
The real problem here is two-fold. 1) There is no temperature protection and 2) considering the orientation of the PR valve and the corrosion, there may not be pressure protection either. PR valves can and will rust to the point where they will no longer function.
Jeff Pope
(661) 212-0738
Still, it might work ![eusa_dance.gif](upload://s9dv24YwSSRLNpgOOSxL1BkwUQ9.gif)
Originally Posted By: afernbaugh
If my memory serves me, a gas fired water heater is an ASME “direct fired” pressure vessel and therefore requires a pressure relief device to be mounted directly to the vessel.
Regards,
Alan Fernbaugh
Five Star Inspection Services
Baton Rouge, La.
Originally Posted By: dbush
Did one the other day, the “tenant” had replaced the TPR valve, it dripped, so he fixed it by putting a water hammer arrestor on the end of the TPR valve.
I made him take it off while I was there.
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Member - MAB
http://www.nachi.org/convention2006.htm
Yup, it stopped the dripping. Of course, so did removing the WHA and tightening the TPR valve a little bit.
Dave Bush
MAB Member
Originally Posted By: pdacey
Actually it won't and it is very dangerous. There is a reason the T&P valve has to be located in the top 6" of the tank. In a configuration like this one the temperature in the tank can reach in excess of 300 degrees before the temperature of the water in the pipe reaches the threshold of the valve. Then it goes boom.
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
www.southwestinspections.com
![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif) ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif) ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif)
He should of just put a galvanized plug in it
