The only way to tell for sure is to look at the truss engineering package, But I have never seen it don like that. It think it is structural deficient at the least.
I’d call it out.
I personally agree. Never seen it done like this. I do not honestly think it will ever manifest into a serious structural issue, but deficient is deficient and we want to be accurate.
Just a thought. Some engineered trusses don’t require a ridge beam. This being a transition area may not required one and although awkward to the eye, may be perfectly fine.
The short cantilevered 2x4s are probably stiff enough to support the roof sheathing, but I don’t think a truss designer would have designed it this way.
Another amateur framing a roof that doesn’t know how to do it right.
Looks like crap, but it won’t go anywhere and hold up and the bottom line is, it is not right. Not the right way to terminate sleepers at a ridge.
I actually have a meeting set with this particular builder tomorrow for a completely different reason. I told my inspector to note this in his report, and I will discuss it personally with the builder tomorrow.
Best way to approach it, gradually bring it up and ask who he he uses as his roofing contractor. At least you can point out your concerns but he may back pedal, or maybe not.
