Along with a few interior electrical conditions that were found this is being referred for additional evaluation by the licensed electrician. Sparky comments welcomed for repair recommendations
Originally Posted By: dbozek This post was automatically imported from our archived forum.
Mobile/manufactured homes comes under different codes, however, there should be a disconnect at the meter and the conductors must be protected from damage.
– You cannot help men permanently by doing for them what they should and could do for themselves. Abraham Lincoln
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
You will either need a disconnect before it goes under the MH or you need to bury it 24". An alternative is in pipe, under 2" of concrete.
Bear in mind if you use a disconnect this becomes a <4 wire> feeder and you make up the panel in the home as a sub. That is usually the way it is done in MHs. The panel may already be made up that way so you only have to remove the bonding jumper.
There must be a means of disconnect located within 30 feet and visible from the mobile home. It cannot be attached to the structure either. Because it would be a main disconnect, it would require grounding as well. The service conductors must be protected from damage. A piece of sojw cord is typically used but if triplex is being used as in the above pic, the conductors must be protected from damage.
Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
This is out of my area and I wondered about the disconnect on the mobile too so I went looking for the code rules.
550.32(A) Prohibits the service from being mounted to a "Mobile Home"
550.32(B) Allows the service to be mounted on a Manufactured Home if OK by the manufacturer.
But I do not know if the home in the picture is a "Manufactured Home" or a "Mobile Home"
Originally Posted By: pdacey This post was automatically imported from our archived forum.
In TX, they are one in the same. "Manufactured Home" is the PC way of describing the structure. "Mobile Home" means that the residents appeared on the Jerry Springer show at some point.
Originally Posted By: jtedesco This post was automatically imported from our archived forum.
Paul:
A picture of the actual nameplate would be helpful.
If you can supply the information on that label, it will include the type of building, etc., and should have the signature or name of the inspecting agency.
I did a number of these for the State of Florida. The difference between “mobile” and “manufactured” is HUD compliance. If it is not a HUD compliant building it is an RV or a trailer. That determines which NEC article you use. Lack of HUD compliance will also relieve the manufacturer from making it meet wind code. The last I heard there were no manufactured homes that could reside in most <any?> of the wind zones.
110.3(B) tells you what to do with the parts you buy.
I wouldn’t trust the pamphlet that comes with a trailer to correctly determine what an AHJ will require to hook one up.
Most AHJs use the HUD certification or lack thereof to determine if this is a article 552 “trailer/RV” or a single family dwelling. A 552 trailer requires a post and a disconnect, the HUD can have the service brought directly to the home but it requires a ground electrode system at the home. The HUD unit may still have a post with a disconnect and a 4 wire feeder but it does require a ground electrode.
A non-HUD unit may or may not require an electrode at the trailer.
They do make “RVs” with >50a panels in them and “resident” parks around here can have 100a services on the post.
