Due to difficulty in filing all the winners for Best Defect Picture of the Year, I found it necessary to copy everything here for the end of the year.
My PC was not saving them as I wished and found it better here.
These are the current winners to Date;
Please, if I made an error, let me know.
This home had many items that I could have entered into this months contest but I chose the water heater flue. As you can see in the pictures the single wall flue completely failed in the attic. The water heater was about 25 years old. There was no TPR valve at the water heater.
Apparently, this has been around for a while, but I found it today. You can store what you want (up to 7 gig) and access it whenever you want. If your computer crashes, no problem, you’ve backed everything up and can get ir right back again.
All you need is a microsoft account, ie: live, hotmail et al
Thanks Brian, but it has to do with copy and paste.
Works best when kept in the Inachi system. Otherwise, it won’t paste properly from another source. Limited to 27 pictures as it is within their system.
Original brick column failed, added wooden makeshift log column, log column eaten by WDO, added another wood column, that too eaten by WDO. Then added an unsecured lolly column on a makeshift “footing”. All columns like this.
